跳转到主内容
Having problems installing OS El Capitan
Bought a Toshiba MQ01ABD100 Media drive from iFixit for my mid-2009 MacBook Pro 13" (It is the exact same model that my local MacStore installed a couple years ago.)
Using various how-to's around the internet (since the iFixit how-to is for an older OS X),
I successfully made a bootable USB drive and booted off it. Got so far as erasing the drive using Disk Utility, but when I hit 'Erase" I get the following; "Erase process has failed..." Show Details reveals: "Wiping volume data to prevent future accidental probing failed. Operation failed..." Ran First Aid, everything copacetic. Tried again, same messages.
So I guess my question is: now what?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
添加一条评论
1个答案
已选择的解决方案
Ah! You likely need a new HD SATA cable! This series tends to have a high failure.
Here's the IFIXIT guide you'll need to follow: MacBook Pro 13" Unibody Mid 2009 Hard Drive Cable Replacement and this is the part you'll want: MacBook Pro 13" Unibody (Mid 2012) Hard Drive Cable - Apple P/N 923-0104. And yes, you want the newer part!
This cable connects a SATA I, SATA II, or SATA III hard drive to the logic board.图片
产品
$34.99
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Robert Pillers 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 408
