跳转到主内容
发布于2012年10月23日。酷睿i5或酷睿i7处理器。配备Apple Fusion Drive.
Bank 1 Memory Slot not recognizing RAM--easy way to fix?
Bank 1 memory does not recognize RAM. I tried different brands of ram OWC, Crucial, Kingston, micro" nothing works. The other memory bank is perfect, no matter what brand or what capacity the second bank works. How can I fix Bank 1 memory in Mac Mini 2012 to recognize RAM?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Sadly there is very little you can do here. You can try to clean the modules slot using some can'ed air or some spray cleaner.
But, be careful with the cleaners! Many have oil in them which you don't want. Spray the cleaner onto a piece of clear glass to see if it leaves a residue if it does don't use it!
For the modules you could try using a pink pencil eraser following the contacts (not across).
If this is the same system that has bad USB ports you might want to look at just replacing the logic board.
Sorry ;-{
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Tom 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 380
