跳转到主内容
Repair information for the Asus Transformer Book T100TA. Released ~2013. Model number: T100TA .
I need a BIOS Rescue password for 2017/06/25
There is a box at start up asking for a password and I didn't set it up. It is my tablet but a "friend" thought it would be nice to have it password protected. Now, they cant remember what they entered. I was able to press ALT + R to get to Enter Rescue Password for 2017/06/25. I found this site http://pastebin.com/L3c3rySj# for reset codes but they don't go as high as today's date.. UGH! I tried and tried to enter a correct password, no go.
Does ANYONE have any ideas? Please? I appreciate any input.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
16条评论
Help I need a key for ASUS rescue 2015/4/10. Tried a bunch I think last four keys are BALA.
完成的
Help asus 2017/07/07
完成的
write in the wrong password until it displays a code then post it here noer
完成的
help please rescue code for ASUS x540 sa 2012/1/13
完成的
I need the bios resue password for a asus laptop and the date is 2018/03/28 please.
完成的
显示更多的11条评论
添加一条评论
7个答案
最有帮助的答案
Prueba esta, al parecer se repite cada 10 años ABBL9ABB
这个答案有帮助吗?
得分 2
5条评论:
POSTED: 2017/09/28
I need a BIOS Rescue password for 2017/09/28 or anything for a later date within next few days, Please.
There is a box at start up asking for a password which my daughter set up but can't remember what it is. I was able to press ALT + R to get to the screen enter rescue password for 2017/09/28. I found this site for reset codes but they don't go no higher than 2012..... UGH! I tried and tried to enter a correct password, no go. Please someone help.
Does ANYONE have any ideas? Please? I appreciate any help I can get
完成的
Can anyone help me from 2017/10/02 and days following
完成的
Use the year 2007.. same day and month
完成的
If your rescue password year is 2018-04-29, then the password for it will be the same as 2008-04-29 that is what this answer means. That is how it works. The password can be found here https://pastebin.com/L3c3rySj
完成的
Mine says 2012/01/01 in that link it starts at 2002/01/02 can you help me please
完成的
添加一条评论
Alt+R= 2012/01/06 need your help please. ...Asus pc notebook model T100T....
这个答案有帮助吗?
得分 2
1条评论:
Try this one A2BBAAAL
完成的
添加一条评论
I have the same exact problem but my rescue passwords dated to current so I don't know if this would work but it's worth a try.
Remove CMOS battery and drain all residue power from from the board, hoping that would reset the date settings back.
这个答案有帮助吗?
得分 1
3条评论:
Yes it worked, so I managed to get the date settings back to 2009/01/01 and reset the admin password.
完成的
I need a rescue password the date of 2018/03/11 because I don't know it
完成的
How do i factory reset a asus which the model number is D550MAV
完成的
添加一条评论
I need a rescue password for my Asus T100T 2012/01/02 Help please
这个答案有帮助吗?
得分 1
3条评论:
Try this one ALAA4ABA
完成的
ASUS 2012/04/09 Help me please
完成的
my asus K53E MFD: 2012-02
i need a recue pasword
完成的
添加一条评论
这个答案有帮助吗?
得分 0
添加一条评论
just in case it serves others :
get your Bios date from the POST screen or use free tools like speccy to get it, or type "systeminfo" at the command line prompt and check the results for the BIOS part (bios vendor and bios date).
If you can use windows, set the system date to your bios date, at a time inside the day (say 00:00:00 or 12:00 AM for example). Now reboot and press F2 to access BIOS.
Enter directly your password derived from your Bios date as stated here : https://pastebin.com/L3c3rySj
Note some PCs require to enter a wrong password first then the display changes from "password" to "rescue password".
Enter your password as you would on a QWERTY keyboard : it means for example that
1-9 &0 are on the 2nd row under F1-F11 without pressing shift,
3rd row begins with Tab,QWERTY
4th row letters begin with ASDFGHJKL
5th row letters begin ZXCVBNM
When password is OK, the current date being the BIOS date, BIOS panel opens.
Then go to "security" menu and set an empty password for Administrator an user.
Returned message should read "password uninstalled" or something similar.
Next time , F2 will not ask for anything if Admin password was correctly blanked out.
This worked for me for an ASUS X73S having a BIOS date somewhere in january 2009.
Hope it helps any further reader to get some old ASUS back to use.
这个答案有帮助吗?
得分 0
添加一条评论
sadly, none of the methods have worked, and i've been very thorough...only way now is David Zou's method or manage to flash them with..maybe Kiosk? whatever method works will require obliterating the password lock...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Diana Jones 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 41
总计 21,913
