跳转到主内容
加入维修社区 - 创建账户
PlayStation 3 Slim是PS3的第二个迭代机型,机器型号CECH-2000。索尼电脑娱乐推出此机型来修复初代“胖机”PS3的诸多硬件问题,于2009年9月1日发布。
PS3 display is not working
I'VE ALREADY TRIED THE HOLD DOWN that "resets" the display but doesn't work
I've tried different hdmis, and different ports the controler isn't turning on all the way and there's no yellow light. Along with it is no audio. All the answers I see are the hold down the power and reset but that is not working for me. My TV is fine it displays no signal and I've tried it onto different monitors it was working fine yesterday.
Any help
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
Have you tried AV cable instead of HDMI? Tell me about lights, do you turn console on and green light is there as it should be, but no signal on tv? If so you may have GLOD. Or, maybe try to jiggle hdmi port a little see if that helps, if you get video that way, your hdmi port may be loose.
这个答案有帮助吗?
得分 0
1条评论:
Can you help identify the issue with my PS 3 console, when turned on it only displays black and white dots
完成的
添加一条评论
添加你的答案
Maxie Masters 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 47
总计 385
