跳转到主内容
Released July 12, 2002. Identified by model number K45SSWH.
33 个问题 查看全部
Won't work at higher speeds
KitchenAid Mixer KP26M1XPM5
I live in Costa Rica....so bringing it in for repair won't work.
My mixer is only a couple of years old, and I haven't used it in awhile. The last time was to put a pasta attachment on it and it worked great.
The problem: It works great up to speed 3, then it won't ramp up past that speed.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Improperly Connected Hall Sensor
Before buying any new parts, make sure that the connection between the control board and the hall sensor is nice and snug. The hall sensor, a grey wire with a three pronged end, is connected between the speed lever and control board. This connection could become loose due to the vibrations of the mixer. Also, the mixer will not work if the connection is not oriented properly. Using trial and error, change the orientation of the three pronged connection to see if the mixer will begin to work. The most common sign of a failing hall sensor is if your mixer increases to top speed and then shuts down.
Faulty Circuit Board
If your mixer is still not operating correctly, you could have a faulty circuit board in the back of your mixer. See our guide on how to replace your circuit board.
这个答案有帮助吗?
得分 2
1条评论:
Not sure it's the hall sensor, since it will stay on for speeds 1-3...but it shuts off if I try to go any higher. But, I will check to see if it is connected.
完成的
添加一条评论
添加你的答案
Allison Wood 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 31
总计 5,924
