跳转到主内容
Thin and more powerful than ultra-budget laptops.
20 个问题 查看全部
Noisy fan and overheating problem!
Hi all, my notebook's CPU temp when I run Edge only around 50C, and if I run more apps it starts to get higher and exceeds 60C. In general, fan sounds annoying after 40C 'most time', and it gets worse while the heat is increasing. What could be the possible problem? Does changing the fan solve the issue?
Note:
1) "I cleaned the fan and placed a thermal paste on the CPU".
2) I need the fan to be quiet because I want to record my voice on the PC. At this time I realized that I have a really noisy fan.
Thanks in advance!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Sounds like you need a good cleaning and thermal paste replacement. Luckily, there's a guide to do so, below. Make sure you take static electricity precautions, and unplug the battery. If you don't have any good thermal paste, iFixit has some.
Acer Aspire V5-571 Cooling System Replacement
[关联产品丢失或禁用: IF179-010]
Hope this helps!
这个答案有帮助吗?
得分 2
1条评论:
Thank you, I'm sure I did that we'll. Dose changing the fan help?
完成的
添加一条评论
添加你的答案
Hazem 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 2,286
