跳转到主内容
Repair and disassembly guides for the Compaq Presario CQ60.
Compaq Presario CQ60 black screen issue
Hi,
I have a problem ... laptop screen is blinking and cut the picture frequently ...then I restarted the laptop...works fine but the fan spinning very fast and causes heat also...then after 3 days it suddenly shutdownn while i am surfing net...I started the laptop 2-3times power is on but SCREEN IS BLACK...why what is the issue....and I have cleaned the fan still it blows hot air why?... Please give me solution....please...soon as possible...
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Hello ,
Please give me solutions...
完成的
添加一条评论
1个答案
已选择的解决方案
Are the slots where fresh air is entering the computer clean? The symptoms are that those of the CPU or GPU are getting to hot and the PC is shutting down.
这个答案有帮助吗?
得分 1
1条评论:
Hi,
Problem with laptop issue is solved, mechanic had replaced the damaged graphic card and finally laptop works fine again... Thanks.
完成的
添加一条评论
添加你的答案
Shakti 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 1,280
