跳转到主内容
iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
1158 个问题 查看全部
Error 6 fix?
I've been trying to reinstall iOS 4.2.1 on my old 3G iPhone, but it throws back error 9 or 6 every time. I've already tried most of the common solutions. Can anybody offer any assistance? Thanks!
Update (06/17/2017)
I also forgot, it's stuck in DFU mode, and the iOS was corrupted when I got it.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
Try to flash with 3Utools
这个答案有帮助吗?
得分 3
3条评论:
are you sure all the connections are fine? dock and cable I mean.
完成的
Yes, and I was doing it wrong anyway. :) I downloaded the actual program, and it fails at 13% saying invalid serial number.
完成的
This tool is very useful~ And about invaild serial number, you can try to enter your device to DFU mode and flash again.
完成的
添加一条评论
Your device is stuck on DFU, you can exit that with 3uTools.
这个答案有帮助吗?
得分 1
2条评论:
With the serial number issue, it refuses to flash. It's also stuck in a somewhat damaged DFU mode, so the only way I can get it to even begin the process is by cheating with iTunes and unplugging it once it reenters recovery mode. I'm honestly a little stumped on this.
完成的
If serial number issue issue still exists, there may be hardware issue. You are suggested to get a repairman to check your device.
完成的
添加一条评论
添加你的答案
Nikola Wozniak 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 3
总计 286
