跳转到主内容
The JBL Charge 3 can be recognized by its distinct woven speaker cover and rubber accents. It was released in 2016 and features a fully waterproof design, 20 hours of playback time, and bluetooth connectivity.
Update firmware usein PC
Hi
I have Carge 3 that can't turn on, unless it's connected to the USB port.
A. There is a way to solve this issue? Pressing common button combinations do not work
B. There is a way to update firmware using my PC? The JBL Connect app can't find the device (though I can play music from my android)
Thanks
Boaz
回答此问题 我也有这个问题
这是一个好问题吗?
得分 5
1条评论
How to update JBL Xtreme with PC???
完成的
添加一条评论
12个答案
最有帮助的答案
I have this problem after trying to update my charge 3. Unfortunatelly for me, this method does not work.
这个答案有帮助吗?
得分 3
2条评论:
How to downgrade jbl charge 3? Coz i want to connct it together with jbl flip 3.
完成的
Zu zhzz5 und und jjhhjund h5
完成的
添加一条评论
i think if you plug it in and hold the connect plus button and the volume up button until it turns off it should fix it
这个答案有帮助吗?
得分 2
2条评论:
you &&^& my xtreme
完成的
https://www.youtube.com/watch?v=Ei54MPrA...
Its Locked, Watch this video it will Show how to unlock it.
完成的
添加一条评论
you have to keep the Connect button and the volume + button pressed when the device is switched on
这个答案有帮助吗?
得分 1
2条评论:
Deu certo com esse procedimento !
完成的
Tava com problema na boombox
完成的
添加一条评论
Just fixed mine with same issue.
Follow this sequence:
1. Turn the device on while connected to charger
2. Press the call (phone icon) and the volume up (+) button at the same time and keep them pressed. After a few seconds the speaker will shut down.
3. Release the buttons.
4. Turn the speaker back on. It will automatically enter into search mode... And there you are, memory wiped up.
I then did the firmware update.
这个答案有帮助吗?
得分 0
添加一条评论
I tried this process but did not solve my problem to.
O opened a ticket on support.
这个答案有帮助吗?
得分 0
1条评论:
I have the same problem. How did you solve it? I can't find anything to flash the software. Now my box can't even connect to my phone. It just keeps restarting.
With best regards
Paul
完成的
添加一条评论
I have the same issue. Now my Charge 3 does not connect.
This is terrible !
这个答案有帮助吗?
得分 0
添加一条评论
I had a swollen battery. Check it first. The problem has been fixed after replacing the battery and holding Connect + Volume up
这个答案有帮助吗?
得分 0
添加一条评论
Plug Power and press connect button for a few secounds.
这个答案有帮助吗?
得分 0
添加一条评论
I used the JBL Connect app to update my firmware. I'm using an android device.
这个答案有帮助吗?
得分 0
1条评论:
y qué hay del JBL Flip 3 Stealth Edition? Es un Flip 3 sin Connect, no lleva ni el botón... De hecho ni se puede usar el software Connect, así que es imposible actualizar éste altavoz. Sin embargo el UE Boom 2 Lite que también tengo sí que conecta con la aplicación UE global para esos altavoces, y por supuesto ha supuesto mi decisión de comprar un Megaboom 2 para complementar al "pequeño" UE Boom 2. Está claro que JBL es especial, pero ya que haces un gran altavoz deja que al menos se pueda actualizar fácilmente el firmware.
完成的
添加一条评论
Jbl like to Shut down suddenly when we played 2 or3 song
这个答案有帮助吗?
得分 0
添加一条评论
You must connect the speaker to AC and hold Connect+ and Volume Up. It should be powered off by itself and then you could use it without AC.
这个答案有帮助吗?
得分 0
添加一条评论
My JBL link portable doesn’t connect how do I fix it ?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
boaz mermelstein 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 11
过去 30 天: 37
总计 50,321
