跳转到主内容
Repair information and support for the Samsung Notebook Series 9 15" laptop. Released in 2012. Model number: NP900X5L-K02US.
6 个问题 查看全部
Why is my laptop so slow
I've been using my laptop for over 3 years now, and I have never had any issues with it in terms of performance. However, recently I had to do some simple video editing with premier pro which slowed down my laptop during the edits. I thought the lag was just because I was running the program but it didn't go away after im done with the project. Now my laptop is super slow! Every thing I do has a 2-4sec delay and I can't even scroll smoothly now. Help please!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
It may be that you are running out of disk space. To find out, open file explorer and then click on This PC. You should see a status bar of the hard drive indicating the amount of disk space used and unused, if the status bar is red then this shows that the hard drive is getting full. Right click on the status bar and you can see a pie chart graphic, if the drive is getting full then you can right click and select disk clean up to delete temp files, internet temp files and similar. The pause of a few seconds is consistent with low disk space as the operating system uses a virtual memory file stored on the hard drive and has to write and read smaller blocks of data.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
poscolo 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 1,526
