跳转到主内容
2016年9月16日发售。型号有A1661,A1784和A1785,支持GSM 和 CDMA 格式,存储容量有32GB、128GB以及256GB,颜色有玫瑰金、金色、银色、黑色、新的亮黑和红色。
1364 个问题 查看全部
Both cameras and flashlight not working after screen replacement
After a screen replacement both cameras and flash light aren't working. The earpiece wasn't at first either, then I replaced the front camera ribbon cable and proximity sensor. Earpiece started to work but the cameras are out showing a black screen. Any ideas?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
3条评论:
Have you perhaps tried plugging on the old screen and see if both cameras remain dysfunctional ?
完成的
Did you make sure to unplug battery (including cutting all other power sources to phone before unplugging any other cables) when doing the repair?
完成的
I made sure to unplug the battery before undoing any other cables. I will try to plug in the old screen thanks.
完成的
添加一条评论
2个答案
Maybe the connections are not fully connected.
这个答案有帮助吗?
得分 0
1条评论:
I've snapped on end in then the other to make sure it works. Additionally the earpiece works and that part is connected to the same ribbon cable.
完成的
添加一条评论
Were the cameras working before the screen replacement? If the LCD was broken and you weren't able to check them, its possible the cameras were damaged on the motherboard at the same time the screen was broken.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kayla Ninh 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 549
