跳转到主内容
于2016年3月上市。型号 SM-G930V。
Purple dots after LCD change
Hallo,
I just changed the LCD for a customer of mine and tested everything after fixing it.
Everything seemed to work fine and my customer paid and left my shop.
4 hours later he called my shop and asked about weird purple dots on the lower-right corner, he also complained that the touch is not working on the upper part of the display, which is causing the upper menu not to open (control panel)
the problem is fresh and maybe it will get worse any idea what it could be?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
I see these happen at work occasionally and none of us know what really causes them to happen, sometimes they show up right away, sometimes they show up later. For us they appear to look like a purple "liquid" almost in the corners of the display rather than dots like that. The display was probably just a bad egg. I'd have it exchanged and tell them it was defective. I would also explain to your customer that you had received a defective LCD and that you'd have it replaced, and personally I wouldn't charge them for it as it's not their fault. And swapping a screen on one of them doesn't take that long anyways.
If/when you do that and have a new one, just for the sake of being careful I would make sure you don't have any glass particles, or anything of the sort laying in the area that the screen lays in. And on the board I would take some isopropyl alcohol and a brush and make sure that the contacts on the connector on the board and the screen are clean. That won't fix the LCD you have now, but it may prevent some issues when putting the new one on.
这个答案有帮助吗?
得分 1
1条评论:
Defective LCD. Usually caused by improper installation of the screen. Too much pressure in a corner causes these dots. Perhaps the phone's frame was dented in a corner and/or not flat?
完成的
添加一条评论
添加你的答案
lahavadam 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 1,462
