跳转到主内容
Announced September 9th, 2014, this device is Apple's first foray into smart wearables. iFixit's repair manuals are applicable to Apple Watch (steel) and Apple Watch Sport (aluminum).
210 个问题 查看全部
Has anyone successfully replaced the Display Flex Cable?
I know it requires board level soldering. I saw the first two videos of a three part series that seemed pretty good. But alas, I'm not sure the gentleman ever finished the repair, because there isn't a third and final video. It looks relatively straightforward from the point where he left off.
I picked up the watch for a very minimal investment and the cable is inexpensive. So I figured what have I really got to lose?
I'm just curious if anyone has successfully completed this repair? Do you have any advice, if so? Or is there a guide somewhere that I haven't found yet?
Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
3个答案
最有帮助的答案
hey! Apple has been using this connection style for some time now to save thickness.
I have successfully replaced this type of connection in ipads for their Charge ports, and ipod 5th gen as well,
I have not done this specific replacement, but i beleive the process to be very similar on the watch, just on a smaller scale. if you plan to do this, i suggest a 10X + Microscope. it does require some practice, as it is a specialized skillset.
这个答案有帮助吗?
得分 2
2条评论:
Hmm, I don't have one of those. I haven't soldered anything this small before. Mostly I've done stained glass and simple repairs on wiring to battery compartments. I have worked with other tiny things before. (Assembling and doing better quality painting on 28mm miniatures, etc.) I hate to just give up on the watch, but I don't want to ruin it because I was too stubborn either.
I have another Series 1 (the one for repairs is a Series 0) that is in excellent shape but iCloud locked. I guess I could use that one for practice?
完成的
that would be a good idea. the iron tips used in stained glass are usually much larger than the ones used for microsoldering. however, i dont know how fine of work you do with the glass. best of luck, and if you need anything let me know.
完成的
添加一条评论
I am also trying to figure out if it replaceable. I have fixed 3 series 1 38 mm apple watches before and they were simple. The one i was fixing yesterday was very difficult and i got very angry when it did not work. I opened up again and the flex cable was torn just a bit. Please link me to a video that shows how to fix it. I cant find anything! (I dont have much experience with small scale repairs like apple watches)
这个答案有帮助吗?
得分 0
添加一条评论
https://youtu.be/xrJJa0oU8FA
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Katherine 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 19
总计 2,230
