跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3530 个问题 查看全部
Touch screen will only work for 1-2 sec before becoming unresponsive
My phone was working perfectly fine when suddenly it became slow to respond (to touch) and then stopped working altogether. I did a hard reset, a restore in DFU mode, even took the thing apart to look for corrosion or loose connections, nada. My husband figured out that the screen would work for just a few seconds if you let it sit with the screen black for a bit, but it quits responding very quickly.
Our current theories:
Something is heating up really fast to cause a short of some sort
The digitizer is going bad
Does anyone have any clue what is going on?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
已选择的解决方案
Was the screen recently replaced?
Are the corners of the iPhone metal housing frame dented in pushing against the screen?
Is the screen cracked?
Is there a visible gap / lift up between the screen's plastic frame and glass?
这个答案有帮助吗?
得分 1
3条评论:
Screen was not replaced recently, screen is not cracked and frame is not dented. No lifting between the glass and plastic.
完成的
Okay this one is very weird, I've never heard of one like this before.
You might want to get another screen tested on there. It's extremely rare for the touch screen to go bad for no apparent reason.
完成的
Is the screen cracked? Yes and so the below
Was the screen recently replaced? Yes
Are the corners of the iPhone metal housing frame dented in pushing against the screen? No
Is there a visible gap / lift up between the screen's plastic frame and glass? I think Yes
Mine is 7+ .Do we have any solution on this? please share
完成的
添加一条评论
I have seen this kind of problem a few times and diagnosed the screen to find no faults with it.
In my experience this is caused by the memory (or storage) on the device being faulty, full or close to capacity.
Faulty - As your phone is a iPhone 5s, then it is relatively old (around 4 years old), the phone stores it's data on something called solid state memory, 4 years ago the technology for solid state memory was not good compared to now. The MTBF (Mean Time Before Failure) of the memory was quite low initially and over-usage promoted the MTBF to become shorter by constantly using read/write cycles of the memory. Unfortunately this causes things like data corruption and bad sectors, which ultimately cause slowness and eventually total failure, it is inevitable.
Full or close to capacity - If the phone is not running on the latest firmware then your phone may be trying to download the latest firmware updates. If there is no room for the update the phone will constantly recycle the last block of memory with the latest block of the update causing the phone to slow to halt. If the phone is full, then there is your problem. In both of these cases removing unneeded apps and data (music / photos) may free up enough room for the phone to work again properly.
Hope this helps, good luck.
这个答案有帮助吗?
得分 1
2条评论:
My leago xrowerC does the same think. After switching to dark screen and back works for a few click then frees. Phone is empty, and no extra apps are on. Reset doesn't help. Time for a new phone it runs android 8 and cannot be updated. Pity. Steel a good phone.
完成的
Surprisingly, this answare helped me a lot to restore my wife's phone to a working state. That is an old Shaomi Redmi 4. 8GB Internal storage was 97% full. I deleted 2GB user files and the phone became responsive. I also turned off wifi and restarted the phone severasl times, I won't say, I also put it in the fridge, hopefully it helps...Finally became responsive.
完成的
添加一条评论
添加你的答案
Kate Fisher 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 37
总计 2,821
