跳转到主内容
Upgrade logic board with better specs
Hi!
My MBPr is starting to feel a bit slow when working on some projects (I'm a software developer), why I'm starting to think about upgrading my computer. Since I'm not really into the new MBP series, I think about upgrading my current computer. Previously I upgraded the SSD from 128GB to 512GB, and I do have some skills when it comes to hardware assembly.
My question is; is it possible to upgrade the logic board to one with an i7 CPU and 16GB RAM?
Currently, my computer runs off of an i5 CPU and 4GB RAM, so the suggested upgrade would be a huge improvement.
I've found logic boards on Ebay, but they are quite expensive and if I'm about to do such an upgrade, I want to feel confident that it's going to work.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Yes! You can.
But, you are limited to the same build series. In your case if I got your system right here one of these: MacBookPro11,1. You have a intergraded GPU (IG) as such you are limited to the same IG logic board.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Anton Gildebrand 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 67
