跳转到主内容
A1706/EMC 3071—于2017年6月上市,这台13''MacBook Pro以可升级至3.5Ghz酷睿i7动态超频至4.0GHz的Kaby Lake处理器为特征。
276 个问题 查看全部
Butterfly key mechanism (MBP 2017) any different to previous model?
Some MBP Touch Bar 2016 users have reported keyboard issues e.g. stuck keys, non-responsiveness.
The control/option keys on the MBP 2017 seem to have gained new markings.
However, are the butterfly mechanisms in the 2017 model different to the 2016 models? Have they been updated?
Can't seem to find any answers to this. Thanks!
Update (06/10/2017)
Thanks Dan! Though if they tweaked it then it's not the same... I guess I meant to ask: has anyone with knowledge of the MBP 2016 had a look under the keys of the 2017 ones? Are the keys/mechanisms between the models swappable?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
It's the same butterfly design!
Apple might have tweaked it a bit to fix the sticking keys issue. It could also haven been Apple had a QC issue with the first run of the keyboard assembly.
Update (06/11/2017)
I too am not thrilled with the newer butterfly design. Between the noise and the low travel I find my rest position fires them off prematurely. Granted I was at an Apple Store and had not used it for more than a few minutes.
If you are thinking the older 2015 keyboard would work in either the 2016 or 2016 models sadly from the images from the IFIXIT tear-downs shows they are not the same.
If you have a crappy 2016 model and are looking to get the keyboard replaced I wouldn't sit back here waiting! Run the the Apple Store or Apple authorized service center to have it replaced under warranty.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Jammy 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 2,324
