跳转到主内容
首先 你得要准备一部iPad Air(1rd Gen)只支持Wi-Fi的机型 这里我们指的是A1474机型 它拥有64位的A7双核处理器并拥有16,32,64GB甚至是128GB的内存选择
20 个问题 查看全部
The battery of an ipad air drains quickly
The battery of the iPad air drains quickly. Have replace the battery twice and it's still not working. Please I need solution
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Several things can cause Battery Drain issues. You will need to isolate some variables in order to get a better understanding of what is wrong. The problem could be a bad replacement battery, excessive current draw from on of the modular components (camera, button, screen) or it could be a problem on the logic board itself.
Here are some things to try:
  • It could be a bad replacement battery; there are lots of cheap batteries on the market.
    1. Try replacing with a known-good battery or order a good one from here.
  • You could have excessive current draw from one of the modular components; for example, the backlight, a camera or a sensor. You may notice a hot spot on the phone or screen.
    1. Fully charge the battery first.
    2. Disconnect the battery, then disconnect the flexes for the screen assembly, buttons and cameras, leaving only the Lightning Dock connected to the logic board (follow this guide). When you are done, re-connect the battery.
    3. Go back after an hour or more and test the condition of the battery. You will need to download either coconutBattery (Mac) or 3uTools (Windows) to see the battery condition.
  • You may have a damaged logic board. This will require a micro-soldering repair and is not DIY. Drops, bends, water damage or using poor quality charging bricks and cables, can cause this.
Replace a 8827 mAh battery compatible with a 1st Generation iPad Air, iPad 5, and iPad 6.
3.73 Volts (V).图片
产品
iPad Air, iPad 5, iPad 6 Battery
$39.99
这个答案有帮助吗?
得分 3
1条评论:
OK will give it a try
完成的
添加一条评论
Hello, for the first im sorry for my English.
I replace battery on my iPad Air 2. The new battery drains also very quick, i check my ipad for hot spots and it is in the near of screen connector. What can i do now?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
idowu amoo 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 9,599
