跳转到主内容
Third generation of iPad, featuring 4G capabilities, released on March 16, 2012. Model number A1430. Repairs require heat and careful prying.
106 个问题 查看全部
How do you get the digitizer to stay on the iPad frame when replacing?
How do you get the glass on an iPad 3, or any iPad for that matter, to stay on correctly without having any bumps where it doesn’t fit correctly such as around the camera hook or around the home button or the flex cable for the digitizer? I can never seem to get it quite right, and the adhesive a lot if the time starts coming loose. Any help would be appreciated.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
The trick with iPad digitizers is you need to completely clean off the old adhesive from the housing. I use good tweezers to pull off as much as I can and then use acetone and IPA to clean off the residue. You also want to remove any bends along the edge that could cause stress on the digi.
You then need to get a strong adhesive. Tesa Tape 61395 is outstanding and very versatile but I also like to use pre-cut templates from Bowler Tech. They also offer a free sample!
Make sure you test the iPad completely before securing the adhesive.
Tesa 61395 Tape图片
产品
Tesa 61395 Tape
$5.99
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Sam Mencimer 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 59
