跳转到主内容
加入维修社区 - 创建账户
Rectangular Form Factor / 16 GB capacity / Announced September 12th, 2012
My iPod won't turn on
My ipod won't turn on. I tried the disk mode whatever and the diagnostic mode. It won't charge. And when i plugged it in the screen just blinks on and off apple logo. It won't respond to the reset. I tried pushing every button and tried everything but it still won't open
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 10
1条评论
I dropped my IPod down the stairs when it had no case on and it now happens to not turn on. I tried holding down the off button and the home button but it did not work. Is there anything else I should try?
完成的
添加一条评论
11个答案
已选择的解决方案
  • Connect your device to a computer and open iTunes
  • While your device is connected, force it to restart
  • Don't release the buttons when you see the Apple logo
  • When you get the option to restore or update, choose Update
Or other method similar to first one but it is easy way
  • If your screen is black or frozen, you might need to force restart your device. A force restart won't erase the content on your device. You can force restart your device even if the screen is black or the buttons aren't responding. Follow these steps:
  • Press and hold both the Sleep/Wake and Volume Down buttons for at least ten seconds, until you see the Apple logo.
  • On an iPod touch: Press and hold both the Sleep/Wake and Home buttons for at least ten seconds, until you see the Apple logo.
这个答案有帮助吗?
得分 22
10条评论:
This was not helpful at all. My ipod still will not turn on
完成的
It worked for me.
完成的
I held both buttons for over a minute and it still didn't turn on... It wasn't even a week old.
完成的
My ipod did not turn on what i suppose to do pls. Help me tnx...
完成的
my ipod is an ipod touch and the home button is broken
完成的
显示更多的5条评论
添加一条评论
Press the Power button and home button simultaneously, and hold them down. This may take a while but don't give up really quick. Mine took a while to turn on but it did with this method. Hope this helps, and good luck!
这个答案有帮助吗?
得分 15
14条评论:
Nope ... neither way
完成的
not working for mine.
完成的
How long did you have to hold both buttons down?
完成的
worked for me cheers
完成的
Yay, it worked for me also! All of a sudden I had the black screen of death.,(That's what I heard some techies call it on youtube). Anywho, I've been using my Nano for exercise, and keeping track of my steps. Great little music player, and step keeper. I am so happy that this fix worked. Thankx guys!
完成的
显示更多的9条评论
添加一条评论
mine is, when my ipod is charging it will open, but if you disconnect the charger it will off automatically
这个答案有帮助吗?
得分 1
1条评论:
have the same problem
完成的
添加一条评论
Well if your iPod is charging and it is on but when you disconnect it from the charger and shuts it will usually mean you have one time left it on the charger way to long and it has killed the battery. Or if it is around 50% charged and you plug it in and charge it, it will mess up the battery. What you need to do is just let the battery totally run out and then wait for 10 or 15 minutes to charge it, then your all set.
这个答案有帮助吗?
得分 0
添加一条评论
Yayy it worked for me…thanks Annie Jackson
这个答案有帮助吗?
得分 0
1条评论:
It also worked out perfectly for me. Thank you so much....Susie Graham
完成的
添加一条评论
i have an ipod touch just pops up with the itunes logo and if you update it happens again and if you turn it off and back on it pops back up
这个答案有帮助吗?
得分 0
添加一条评论
I was just wondering if anyone could say why when I bought a brand new iPod 7th generation that when u put it down say overnight sometimes it will be a blank white screen when I try to go to certain areas for instance settings or my email. I push the restart button and then it restarts fine I have to enter my password and then it’s fine. But my question is why is it happening at all this is a brand new iPod!!! This keeps happening! Ty
这个答案有帮助吗?
得分 0
1条评论:
It work for me thank goodness
完成的
添加一条评论
My iPod is about 3 years old and randomly last night it stopped working. It will not respond to chargers and the buttons don’t respond either, the screens just black. Ive tried just about every type of restart and none of them do anything. My iPod is basically my phone and I need it. What do I do now?
这个答案有帮助吗?
得分 0
1条评论:
did you try press/hold the top button and hold the volume down button at the same time?
完成的
添加一条评论
i don’t feel bad for you…. my name is meane
这个答案有帮助吗?
得分 0
添加一条评论
I got a white screen when I turn it on and I got a iPod nano generation 7
这个答案有帮助吗?
得分 0
添加一条评论
Worked for me cheers
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
iries mangao 将永远感激不已
浏览统计数据:
过去 24 小时: 10
过去 7 天: 87
过去 30 天: 436
总计 79,117
