跳转到主内容
iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
1158 个问题 查看全部
问题已关闭
Home Buton Stop Wporking.
I opened my iphone 3g in an effort of changing my original housing, everything was going according to plan until i realized that my home button stop working. i havent been able to make it work again and to remove the housin you all know that you dont need the touchscreen so i donnt believe i damage it while doing the change...
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Are the pins still in tact? If so, then test this assembly into another iPhone. If it dosn't work then it looks like the Home Button needs to be replaced. If it does work, then your Dock Assembly will need to be replaced.
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 919
