跳转到主内容
加入维修社区 - 创建账户
The Samsung Galaxy Note 4 is a cellular smartphone that was released in October 2014. The Galaxy Note 4 Model Number is SM-N910, SM-N910A, SM-N910T, SM-N910V, or SM-N910R4 for American variants.
Battery overheating despite replacement
Battery overheats to around 68 C then device shuts down. Power saver does not work. I installed a custom ROM (Lineage OS 14.1) and that seems to work, it functions like a normal phone except I can't play games for long periods. Idle temps on custom ROM and set to battery saver sit L's around 42-45 C. I have tried replacing the old battery (Anker 3220mAp) with another anker battery but still the same problem. Could the sensor on the motherboard be dead or damaged? As when it says temps are 66C the phone does not feel hot at all. Even when removing the back cover to feel battery, it does not feel hot. Any ideas?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
issue still persist even with OEM battery. Going to give up on this one, sell it for parts. Thanks anyways
完成的
添加一条评论
1个答案
最有帮助的答案
I recommend replacing the battery with a genuine Samsung battery.
这个答案有帮助吗?
得分 1
2条评论:
Yeah, I ordered one on amazon, arriving tonight. Will see if that works!
完成的
new battery just arrived, idle temps are 45-46 C but off power saver, on power saver it sits around 41-42C
完成的
添加一条评论
添加你的答案
ameer7867 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 9
总计 454
