跳转到主内容
Formally called the Chevrolet C/K, C/K is a series of trucks manufactured by General Motors and marketed under the Chevrolet and GMC brands. The C/K line includes pickup trucks, medium-duty, and heavy trucks.
301 个问题 查看全部
Turn signal fuse keeps blowing on 97 Chevy C2500.
The turn signals worked fine but the hazard lights did not, however when I would hit the brakes all of my turn signals would illuminate without blinking. I had wiggled the press button a little bit and finally did get the hazard lights to work as they should, however the brakes would still illuminate them without any blink. Also after getting the hazard lights to work now my turn signals do not work at all. I bought a new hazard light/turn signal switch with wiring harness, figuring it was a bad switch but that did not do the trick. I did find I had a blown fuse so when I replaced the fuse and turn my turn signal on it instantly blew that fuse as well. Thinking it may be a bad relay or a bad ground but any ideas or help that I can find would be great. I got a pretty good deal on the truck but if I cant pass an inspection then it isnt worth a whole lot at all. Thanks in advance!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Check wiring to the trailer lights ( pig tails located under tailgate). A bad ground in your light harness will likely be the culprit. The hazards and turn signals also rely on a flasher relay to operate. Check out or replace ( located next to your fuse panel next to parking brake )
这个答案有帮助吗?
得分 1
1条评论:
Mine was the trail wiring pigtail
完成的
添加一条评论
添加你的答案
Richard Champion 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 10
总计 2,454
