跳转到主内容
2016年9月16日发售。型号有A1661,A1784和A1785,支持GSM 和 CDMA 格式,存储容量有32GB、128GB以及256GB,颜色有玫瑰金、金色、银色、黑色、新的亮黑和红色。
1364 个问题 查看全部
Earspeaker/Earpiece not working after screen replacement iPhone 7 Plus
Hello Guys,
I have replaced a iPhone 7 plus screen. After the screen replacement the speaker above does not work anymore. Everything else is working, front cam, proximity sensor etc is all working.
I replaced also the speaker and the flex with new one, but without succes.
Who can please help me out of this problem?
Thanks a lot.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
did you try to put back the old speaker? what was the reason to change the flex and the speaker and not use the original ones?
完成的
添加一条评论
3个答案
已选择的解决方案
Problem is fixed! It was a faulty front camera flex. We tried like 4 flex cables (with apple logo original), but only one worked.
这个答案有帮助吗?
得分 0
1条评论:
hope it is the same problem for me... Replaced an iPhone 7 Plus Cable Today and it got stock in the booting process, then took the original one, but now the earspeaker didnt work...
完成的
添加一条评论
I believe I did the same thing today and all you had to do is barely hit the flex or cut it slightly I didn't even cut it what I did was is I somehow split it right at the part where the earpiece connects with 4 for gold pieces are,right at the right corner on the very corner I tried to lift it in the flex like split like basically when you peel off tape,going to try a new flex tomorrow and we'll see what happens
这个答案有帮助吗?
得分 0
添加一条评论
Here's a picture of the damage
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Nisay Atsu 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 3,221
