跳转到主内容
加入维修社区 - 创建账户
首先 你得要准备一部iPad Air(1rd Gen)只支持Wi-Fi的机型 这里我们指的是A1474机型 它拥有64位的A7双核处理器并拥有16,32,64GB甚至是128GB的内存选择
Replacement digitiser now misbehaving
Replaced the digitiser after daughter cracked the screen, worked fine at first (although I didn't test the responsiveness of the entire screen - assumed if you could unlock the device with a PIN, open some apps, it was good). About a week later it seems to behave sporadically (either sometime not respond or open random apps / type random characters). Seems worse one horizontal orientation that the other. This was an aftermarket replace, could that be the cause? Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
Poor quality aftermarket digitizers could certainly cause this. Some of the cheap ones suffer from ghost touching as well. It could also just be improperly connected or you may have kinked the flex when you did the repair.
Lesson learned, always check the entire surface of the digi before sealing it with adhesive :>)
Take a look at the ones iFixit sells, they are good quality.
Replace a front panel assembly compatible with iPad Air. Assembly includes the glass touch panel (digitizer), blank home button, camera bezel, and adhesive.图片
产品
iPad Air Screen Digitizer
$29.99
这个答案有帮助吗?
得分 3
1条评论:
Thank you. I'm in the UK hopefully they ship here
完成的
添加一条评论
Maybe you have a defective screen but before ordering another check if putting pressure on the bottom part of the screen left and right of the Home button. If this causes your screen to touch by himself the solution would be to put some tape on the little components marked with red and tape also the bottom part marked in green.
Sow you have some component on the home button flex which are not always isolated, the little cercle.
And sometimes you have the bottom part of the digitiser showing the lines which go to a segment of the digitiser that need isolation also.
这个答案有帮助吗?
得分 2
5条评论:
Great I'll give your suggestion a try. Thanks
完成的
Looks like this could be the problem, pressing either side of the home button causes the problem. Forgive me but its not clear to me from the photo which parts I need to cover. Do you have any other photos or instructions? Thanks
完成的
Only monday once i'm back at the shop, i'll add a more detailed photo to the answer
完成的
Thanks. Any luck with the photos please?
完成的
Hope it helps
完成的
添加一条评论
Thanks for the advice, I tried covering the areas mentioned with tape but no improvement (pictures below). Purchased another screen which is now installed & seems to be working well, lets hope it lasts.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
JohnyB 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 14
总计 212
