跳转到主内容
加入维修社区 - 创建账户
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
iPhone reboot loop, can't connect to computer
I recently acquired an iPhone 4S (A1387) from one of my teachers, and it was in pretty rough shape. The screen is severely cracked to the point where the main logic board is visible. I tried plugging it in to my computer but the screen wouldn't turn on. When I plugged it into a 10W iPad charging brick, it started booting, and then turned off again. It did this a few times until it finally was able to get onto the lock screen. But then it just turned off again. I found that if I held down the power and sleep buttons at the same time, it wouldn't turn off while it was still plugged in. I verified that the cable is OK with an iPhone 3G. There is a password on the phone but my teacher doesn't know it. I think I might need to restore it without the computer.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Uh.. You can only restore an iPhone with the use of a computer..
You need to restore the iPhone 4S via computer once it has a passcode on it and nobody remembers it.
Then hope it does not ask for an apple ID after restoring the phone.
Sounds like a defective power button could even be home button.
Did you try testing those buttons individually similar to above?
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Treacherous Toast 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 8
总计 158
