跳转到主内容
第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
2375 个问题 查看全部
replaced battery will not charge
Hi, got a new battery and replaced it per instructions, ran the battery down below 10% as instructed, tried charging it, nothing happened, used 3 different cord on wall charger, also tried my car charger and nothing, connected to laptop to see if the computer saw the device, still nothing, any ideas? removed battery a few times to make sure the plug was right. any other way to charge the battery besides using the 30 pin connector?
Thanks Greg
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
This can be three different things. Two easy, one bad news.
First this is faulty charging port. If the device is on but no charging connection, this charging port component will need to be replaced.
iPhone 4 Dock Connector Replacement
There is a difference in charging port between CDMA and GSM models. Make sure you get the right one.
Second thing could be a faulty battery. Although this is more unlikely aince the battery does seems to operate.
Third, if all else fails is motherboards issue, which you will need to contact a professional for advise on how to repair the device.
Happy repairing!
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Greg Wischmeyer 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 6
总计 54
