跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
Marks on display after separating glass
Hello
I have a question for people with more experience in LCD separation. Look at the picture in the second link below - there are several marks on a display of an iPhone 6 I have not encountered before, red line and dark spot.
The display was broken after a fall. Here is a picture before separation:
http://imgur.com/a/Lmege
And here is a picture after separation:
http://i.imgur.com/2uC0v37.png
There were none of those marks before glass separation so I am wondering if this could happen because of an unprofessional separation or is it possible that it just somehow was not visible before (with glass on a display)?
According to the technician words, the dark spot on the bottom right side marks a place when the display is a bit bent - which was not visible with the glass glued on top of the display.
Thank you in advance
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
已选择的解决方案
Vertical red line looks like it is on the polariser film you have fitted (they have protective films you remove), along with the black/grey circles. The dark smear in the bottom right is probably where liquid has leaked into the backlight (when you were cleaning the glue), but it is difficult to tell from picture.
这个答案有帮助吗?
得分 5
4条评论:
So it means that the technician made possibly something wrong? I was not separating the display, this picture is the only one he sent me.
完成的
Yes. Tell him to remove the protective film from both sides of the polariser. Smudge is probably backlight panel, when he cleaned the glue it has leaked inside.
完成的
Thank you. Your explanation with leaked glue sounds more credible than his argument with a bent digitizer. Or is it possible that digitizer could bend after a drop? I believe it would break, not bend.
完成的
A bent digitiser won't cause that mark, it is where the liquid from cleaning the old glue has leaked into the right side. Most likely the digitiser would break anyway, like you have said
完成的
添加一条评论
添加你的答案
Mirek 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 4
总计 145
