跳转到主内容
2016年9月16日发售。型号有A1661,A1784和A1785,支持GSM 和 CDMA 格式,存储容量有32GB、128GB以及256GB,颜色有玫瑰金、金色、银色、黑色、新的亮黑和红色。
20 个问题 查看全部
Phone restarts when I try to call someone?
Replaced my screen and now when I call someone or someone calls me I can't hear them and the phone restarts. Also I can't answer the phone
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 8
2条评论
Same problem its very odd. I removed my apple id and did a full factory reset to see if it may have been a software issue but no change still switches off the on again. starting to think its a hardware issue. Anyone got any idear's I'm told to replace the camera proximity sensor flex cable but not sure how that can be connected to calling.
完成的
Front camera and sensor I have read elsewhere has been damaged when the screen was repaired
完成的
添加一条评论
10个答案
已选择的解决方案
Let's try a force restart, if that doesn't take, then let's try backing up the phone, delete and restore to the backup. If the problem persists, put the phone into dfu mode, and restore to the backup. If the problem continues, then come back, and we'll try something else
如何强制重启 iPhone 7 Plus
Plug your device into your computer with a USB cable.
Turn off the device.
Hold the Power button for 3 seconds.
Hold the Home and Power buttons for 10 seconds.
Release the Power button but keep holding the Home button.
More items...
这个答案有帮助吗?
得分 2
13条评论:
This did not work
完成的
None of those things, huh? How much free space do you have on that phone? How many gigs of free storage?
完成的
The link page is 404
完成的
That's a bit weird @ets. Anyways. Fixed now. Thanks
完成的
Smells like a damaged front camera ribbon cable assembly to me.
完成的
显示更多的8条评论
添加一条评论
最有帮助的答案
I solved that problem by changing ear speaker flex and ear speaker too.
这个答案有帮助吗?
得分 13
4条评论:
Yes! This fixed my issue too. Thanks.
完成的
How do you do that
完成的
Thank you SO MUCH man only answer that worked!!!
完成的
I change mine and its solve but I try to figure it out mine nothing is broken and I try to re-solder later of the connect of the ribbon selfing with the one where to the ear speaker
完成的
添加一条评论
Fixed by replacing the ear piece/camera flex cable for me as well. I was a little rough on the original cable where the square double sided tape.
这个答案有帮助吗?
得分 7
1条评论:
How much should that cost? I am having the same problem and need to go to a cellphone store and have it fixed. :(
完成的
添加一条评论
I have the same issue. Does the phone reboot if the call is going over Bluetooth? That has been my only other difference.
这个答案有帮助吗?
得分 0
1条评论:
That`s the problem of Bluetooth chips.Check first the Bluetooth is functioning or not if works.Simply factory reset the phone.
完成的
添加一条评论
I am having the same issue when trying to place a call with the replacement scree, now with the cracked screen as well that was put back in place.
这个答案有帮助吗?
得分 0
添加一条评论
I have Android when i shut my phone off when i re start the phone while it is rebooting it rings four full rings .When that happens it will tell me i have a new voice mail of course there is nothingin VM.
这个答案有帮助吗?
得分 0
添加一条评论
I have the same issue but my phone doesn’t restart if I’m on it . Only when my phone is being left alone, it starts restarting
这个答案有帮助吗?
得分 0
添加一条评论
Had the very same issue. Fixed my iPhone 7 Plus by replacing the flex cable/front camera assembly/earpiece. No visible damage on the flex cable so not sure whether it was the flex cable that was damaged or just faulty hardware.
这个答案有帮助吗?
得分 0
添加一条评论
I solved my problem after taking the camera and speaker back off and resetting the flex ribbon cable. I think the gold contacts weren't making a good connection. I would take a good look at the ribbon cable and be sure you seated it correctly. Maybe clean the gold contacts. And reseat the speaker securely. Every few minutes this iPhone shut off on its own and if you placed a call it would reboot. I'm only assuming that poor placement or dirty contacts are the reason it reboots. Maybe the OS did the reboot to prevent damage if there was a short. I really recommen you take a second look at the ribbon cable and possible poor connection in this area.
这个答案有帮助吗?
得分 0
添加一条评论
Disconnected the front camera assembly and it worked for me. Cool. Thanks man. I was tripping that I had a baseband problem I don’t feel like f-ing with.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Joshua 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 35
总计 69,677
