跳转到主内容
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 123 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
2690 个问题 查看全部
iPhone 6s LCD Backlight not working
I recently fixed an iPhone 6s after a fall into water using some isopropyl alcohol and an ultrasonic cleaner, after changing the battery the phone (almost) works, but there is a problem, the phone works without any problem but I need to use a flashlight to see the display because the backlight isn't turned on. My idea was to buy a new backlight panel and replace it because I think that the contact with water shorted it. What do you guys think should I do? Replace the back light panel or the problem is in some component on the logic board?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
已选择的解决方案
You can't easily replace a backlight panel on an iPhone, they are fused with the LCD and the rest of the screen. It sounds to me like you have a blown backlight circuit on the logic board. It's usually the filter but it can also be the rest of the circuit.
If you did a professional water decontamination, then it's either the screen or the backlight circuit on the logic board. If you have access to a known-good screen, try that first. Otherwise, you will need to find a reputable shop that does micro-soldering.
If you just put the logic board in a jewellery cleaner, then I would highly recommend you have it professionally decontaminated using a laboratory-grade ultrasonic cleaner and the proper chemicals.
这个答案有帮助吗?
得分 3
添加一条评论
Hi mate, after water damage it most times kills the screen, replace it. Or if you can, test that screen on a known good phone
unless you want to go to the extreme first of stripping down the phone and Searching the main board for blown components, if you have the tools and the ability, cool, if not its a big job ! The screen is your starting point
Cheers
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
XenoBooT 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 5,979
