跳转到主内容
2008 netbook; Model ZG5 AOA150-1691; 8.5" screen; 1.6 GHz N270 Intel Atom Processor
74 个问题 查看全部
My Acer Aspire One ZG5 suddenly won't power on: what to do?
I used it last night, and I was able to shut it down properly. Since I know the battery level is low, I charged it. As soon as the red LED turns green, I pulled off the charger plug. The next day when I opened it; it won't turn on at all. I plugged the charger, the charging led was lit, but pressing the power button won't turn on the unit. My laptop was just a month old. What can I do? Is it really time to go to a technician now?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 5
添加一条评论
10个答案
已选择的解决方案
If your unit is a month old I would take it to the dealer for warranty repair. If you have no local dealer call the Acer service department for assistance. here is a link to the company. Good luck.
http://www.acer.com/aspireone_amd/en-us/...
这个答案有帮助吗?
得分 4
1条评论:
I have a Acer Aspire One 725 0487‎. I'm not sure why I was taken to this page. Google must think it's very similiar machine. Anyway mine is out of warranty and I've already taken it completely apart, and no, there are no burned or missing/broken parts, no visible cold solder joints and unfortunately no blinking led saying here's the problem. I looked at the voltage on the power button with power plugged in and battery hooked up and there is about 3 volts at the button that goes away when you push it. Meaning the button it's self is good. Being that it's all SMD tech I really don't have much hope of repairing it myself. but maybe if I knew what board it was for sure (looks like the main board since the battery plugs directly into it and still has no power.
anybody know? what board it is ? I haven't tried to price it yet, or even see if it is sold or swapped as apple does with their proprietary parts. Or at least they did years ago.
完成的
添加一条评论
remove the battery and the power cord. hold in the power button for 15 seconds to reset the computer. reinstall the battery, plug in the power and try again. Hopefully it will power up. If you have installed RAM in the socket it could be the bad RAM causing this as well.
这个答案有帮助吗?
得分 3
3条评论:
The power reset worked for me. All other answers appear to have come from people who have never even seen one of these.
完成的
Why was my post that this answer worked for me imediately deleted as spam?
完成的
The problem solved
完成的
添加一条评论
For my Aspire one 725 this worked after 30 hours of trying all the practical answers I could find. Hold Volume up and Power On buttons together for 15 seconds. Hey Presto, Magic.
这个答案有帮助吗?
得分 1
3条评论:
This worked! Thx :)
完成的
Worked for me too
完成的
Didn't work for me...
完成的
添加一条评论
This is a common problem with the Bios being wiped, probably. You will have to recover the bios. The below link will help.
http://www.leosquarez.com/acer-aspire-on...
这个答案有帮助吗?
得分 0
添加一条评论
None of the above worked. Notebook will NOT power on.
这个答案有帮助吗?
得分 0
1条评论:
Jack, none of the above worked for you. Why not just go ahead and ask your own question and give us ALL the details so you can get an answer that might work for you.? Click on the link on the right side of this page "Ask a question"....
完成的
添加一条评论
system repair.. and ishut it down,,then it doesn't turn the powerwhat canido
这个答案有帮助吗?
得分 0
添加一条评论
I had a loose connection on the power (inc. USB) board. None of the above worked. The unit was dis-assembled... then, on careful re-assembly the unit powered ON at a test stage (while the top was still off I pressed the power button)
这个答案有帮助吗?
得分 0
添加一条评论
On my one the power button is on but it doesn't switch the fan just comes on and thats it
这个答案有帮助吗?
得分 0
添加一条评论
I have a problem with my aspire one ZG5… I used it for a day then after I used it, I turned it off and store it in my closet where I usually hide it… the next day, I tried to use it again but it won’t open… It is charging though… Hope you can help me
这个答案有帮助吗?
得分 0
添加一条评论
Thanks for the tips.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
John 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 17
过去 30 天: 33
总计 53,138
