跳转到主内容
Repair guides and support for the sixth generation of Ford F-Series trucks. Models include the F100, F150, F250, F350, and others.
16 个问题 查看全部
问题已关闭
duraspark ICM wire connections
73 F100 Electronic distributor (no points)
Need correct wiring for each of these devices in my circuit:
Ign switch (Blk w/grn, Yellow, Red, Pink & two Red w/grn - on one terminal )
ICM (2 + 4 w/Blue square)
Starter Solenoid
Ballast (ceramic 2 terminal)
Coil (screw terminals)
Electronic Distributor
Wiring diagrams from net arent working.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
Henry,
You might try contacting some of the companies that handle restoration parts for those trucks.
Here are a few I Know of. They can steer you in the right direction if they don't have it.
https://www.blueovaltruckparts.com/
http://www.lmctruck.com/index.htm
http://www.cjponyparts.com/ford-f100-par...
https://www.npdlink.com/store/catalog/19...
Like I said, they may know where to go to find what your looking for. Good luck.
这个答案有帮助吗?
得分 0
添加一条评论
Henry,
I'd try and contact one of the companies that handle restoration parts for your truck. If the don't have what you need they can sure steer you to who does.
这个答案有帮助吗?
得分 0
添加一条评论
1973 ford truck shop manual: https://www.fordshopmanual.com/ford-truc...
1973 ford truck parts catalog: https://www.fordshopmanual.com/ford-truc...
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 350
