跳转到主内容
索尼的新一代电视游戏机,于2013年2月20日发布,并于2013年11月15日开售。
1697 个问题 查看全部
Ps4 randomly shuts down
I am having a problem with my Playstation randomly shuts itself down. There is no warning nor red light. It shuts down like it was cut out of power. Powering it on immediately after the shutdown gives around 10 sec of blue light then it shuts down. What I do is unplug the device from electricity for a minute then plug it back in and it works. The shut down happens randomly. Sometimes it works for an hour or it stays up for 4-5. Though it never stays more than 6 hours.
( it's a shared console. My brothers play as well)
I have the console horizontal and nothing near it ( so it can get as much air as it need ). Bought an external fan in case it was a heating problem, but the problem is still there ( the fan is connected to the TV ). Since I live in an area where warranty doesn't count, I decided to open up the console and I did clean it. I have also rebuilt the database.
The device is connected to a UPS. Tried to connect it directly without the UPS, but it still shuts off.
Any hint on what else I should be trying? I can't send it to repair ( can't trust "repair" shops here. It's Iraq...) I would rather sell it and get the slim version, but I would love to try to fix the device.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 6
9条评论
I have a similar problem except what happened was my PS4 randomly shut off when I was on the PlayStation store like literally acted like I was out of power but then when I went up to it to try & turn it on it was still black(no
完成的
Mine won’t turn back on and it didn’t have no light it’s like it lost power but nothing works
完成的
Mine also turns of randomly and I have a ps slim
完成的
More than likely you have to get a power supply and install it it may have overheated and basically killed the power supply
完成的
My ps4 sort of shuts off because in the screen it says no signal but when I look at the ps4 it has a white light or some times it has a black screen and a white light and sometimes it’s just all no signal and no light
完成的
显示更多的4条评论
添加一条评论
17个答案
最有帮助的答案
I had this problem, and found it was my use of a multi connector which also had an HDR connected to it. When the HDR switched on to record a TV programme, the multi connector switched to that signal. Either remove other connected equipment while playing, or quickly pause your game, switch the connector back manually, and away you go. Works for me, hope it does for you.
这个答案有帮助吗?
得分 3
1条评论:
I just had this same problem weird thing is after my ps4 slim did it my sone came out an said his ps4 did same thing at same time. Only connection therw is between our systens is both run through lan cable to same router an i gameshare on his ps4 with my account. Other than thout differnt wall outlets differnt rooms differnt accoubts signed in.
完成的
添加一条评论
I talked to the ps people and they said turn off your ps4 completely. Once completely off hold the power button until you here the 2nd beep you’ll get to the safe mode menu. Once you get there click on the 5th option (can’t remember which it was but it was something about re do database) once that’s finished turn off ps4 and unplug for 3 min and it should be good
这个答案有帮助吗?
得分 2
2条评论:
This wasn't the exact solution for me, but it led me to one, so thanks! I tried the database fix in safe mode, no luck, then I thought i'd try the reset video resolution option, and that did it. I was able to get the ps4 working in 480p mode, then 720p mode worked, which is all I need for the smaller tv this secondary ps4 is on. When I try 1080p (original ps4) it crashes every time it starts, or within a few minutes. No dust in the system.
完成的
Same problem here. Just shuts off with no warning. Though when they released the 7.50 update it killed my Blu Ray drive in my PS4 slim so I think my PlayStation is slowly dying lol.
完成的
添加一条评论
Is there any signs of overheating? It seems the system may be getting too hot and shutting down to protect itself. Is the console hot (I know its redundant for you being in iraq)
这个答案有帮助吗?
得分 1
6条评论:
It gets hot that's why I bought an external fan. Shouldn't it change the light to red before shutting down? Mine doesn't.
完成的
In most cases yes, it will warn you with a red light before shutting down, Is your ps4 in a non dusty area? If not the interneal fan may need cleaning
完成的
I did do that. I opened up the console and cleaned the fan.
完成的
Now that we eliminated one issue, lets talk power. Do you lug it directly into a wall? I use a surge protector. If you do have yo tried other plugs?
完成的
Yes, I did that and I even moved to another rom just to check.
完成的
显示更多的1条评论
添加一条评论
If you're still having this problem, go to [settings] then [initialization] then [initinalize system] and click [full initialization]. If that does not work, go into "Safe Mode" and click [rebuild data base]. Also make sure your system is up to date with its updates. Hopefully this helps !
这个答案有帮助吗?
得分 1
添加一条评论
I also have the same problem and i left it for a few months…but then i decided to take it to a local repair shop and when i brought it back still had the same problem and i called him and told him about it he told me it was working fine back at the shop …maybe i should try a different house so i took it to my friends place and it worked fine…i came to realise that my house wasnt giving it enough power (even when plugged direct) so nowadays i make sure everything else is turned off before i start playing and it works fine….let me know if it worked for you
这个答案有帮助吗?
得分 1
1条评论:
Good point and easily forgotten, sometimes an outlets power is drained by other devices or just age of wiring. It never hurts to try a new outlet or power cable.
完成的
添加一条评论
Try just to turn it on and let it on home menu. Disable auto turn off and let it before you go to sleep, remove any connected controllers, camera or disc from console. Try to have all usb ports with nothing on them, usb sticks hub, and Ethernet cable disconnected, I would also recommend to remove it from any wifi network if it is connected.
If next morning is not off then it must be something wrong with power supply which cause it to turn off when is in load.
Hope this will be the beginning of your solution!
这个答案有帮助吗?
得分 0
添加一条评论
it sounds like your ps4 has a contamination issue..ie...dust....it can destroy electronics...remove the covers and use can of compressed air such as keyboard cleaner to get dust from device.
这个答案有帮助吗?
得分 0
添加一条评论
If with or without UPS the problem persists you can also try change power cord and check it with another power outlet if possible. If nothing of the above fix it then power supply of PlayStation 4 is probably faulty. If you are about to open the power supply BE EXTRA CAREFUL and you will need a multimeter ! I would recommend to buy a refurbished one, be careful with the model of the power supply you already have and find the same or a compatible one, there is model name on the power supply itself.
这个答案有帮助吗?
得分 0
添加一条评论
Just boot to safe mode and update system software through Internet, it may fix it
这个答案有帮助吗?
得分 0
添加一条评论
Happened to my Ps4 pro. You probably have a USB cable attached to the front port. Remove the USB attachment and for me I noticed that after I have done that it works without the sudden shutoff. There are 2 ports. Also try changing the ports. I. Now charge my controllers separately..
这个答案有帮助吗?
得分 0
添加一条评论
i had the same problem a few months back, i went into safe mode and updated system firmware , and havent had the problem since, you should try it, it does no harm
这个答案有帮助吗?
得分 0
添加一条评论
For anybody that has this problem and recently put their ps4 in a new outlet, for me it was the outlet, you can test this by plugging any other device (like a tv) and checking if it turns off, if so just avoid using that outlet, for me it was only the top outlet so i just got an extension cord and plugged my tv and ps4 to the bottom outlet, hope this helps
这个答案有帮助吗?
得分 0
添加一条评论
This is a simple case of hard drive malfunction this is caused by the lack of deet power and how well you can change the deets inside the console. I have checked many ps4s and see a pattern in the solution i use to test the reason of malfunction and have concluded that the hard drive needs to increase its deets and if you cant do that you need to get a new one. I beg you first try increasing deets in settings because that is the cheaper and most effective way but if worst comes may I recommend seagate 1tb ps4 edition I personally always use this as a hard drive and have used it for over 4 years and it is still perfectly silent
这个答案有帮助吗?
得分 0
1条评论:
To Alberto, I got a new hard drive and it was good for a few days but it shut off randomly last night so that's not it. At least not in my case.
完成的
添加一条评论
Found a fix. It was a software issue for me. Too many blackouts had corrupted the hard drive. Reintializing the ps4 fixed it. Hope this helps.
这个答案有帮助吗?
得分 0
添加一条评论
I did the complete initialization with reinstalling system software which worked for like 2 days then same problem. Only game I get to work is Dark souls 3.
To Alberto Aneronda, thanks for that fix I have some original harddrives I will try and see if it works. If I'm lucky my disc drive will start working to lol.
这个答案有帮助吗?
得分 0
添加一条评论
Go to ps 4 settings and scroll down to initialize and then click on full initialize. That worked for me
这个答案有帮助吗?
得分 0
添加一条评论
Clean your ps thoroughly. Clean the fan with earbuds and it will
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Alameen 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 20
过去 30 天: 46
总计 138,149
