跳转到主内容
加入维修社区 - 创建账户
The Sony Xperia Z3 is an android smartphone released in 2014 known for it’s long battery life and durability.
Screen corner separated from frame
So my Xperia Z3 is just over 2 years old now and I have noticed that the top left-hand corner of the screen has separated from the frame.
Is there any way to temporarily fix it without ruining repairablility in the future?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Why not just use sticky tape to keep it together? if it's transparent enough, it might even not trigger the proximity sensor.
In any case, it will avoid more dust getting in which will progressively stick to the glue holding the screen to the frame, separating the screen more and more.
The repair will mean changing the glue between the screen and frame, which means following most of the screen replacement guide.
这个答案有帮助吗?
得分 1
2条评论:
Thanks for the advice, Axel, but I had already tryed that and, due to the case on my phone being very tight, the tape just ripped straight off.
My main concern with the corner lifting was when I remove the phone from it's case, the gap opens up to around a centimetre.
完成的
I generally use B7000 Liquid glue to restick the glass back to the frame as a quick and easy solution
Don't put too much and don't put too little, if you put too much you risk covering the proximity sensor, front camera on accident.
Once you have it applied, apply pressure then use sticky tape to let the glue set in between with pressure then take out the tape after 24 hours.
Rub off the excess glue if needed after that.
完成的
添加一条评论
添加你的答案
Shane Bonato 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 16
总计 960
