跳转到主内容
加入维修社区 - 创建账户
Repair guides and support for riding lawn tractors sold under the Murray brand name, currently owned by Briggs & Stratton.
Why won't the arm that raises and lowers the deck raise or lower?
No spring action in arm. Was cutting grass, stopped, went to raise arm and nothing. Stuck down and won't cut grass.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
my john deere model is 2320.
完成的
添加一条评论
3个答案
最有帮助的答案
This could be a result of a connection somewhere that broke loose like the lift links not being connected. If you could give me a model number of the mower I could maybe find a diagram to help you find those lift link and connections.
这个答案有帮助吗?
得分 1
4条评论:
Hey Justin, i'm having the exact same issue with my Murray. Is it possible that you can find me a diagram of the lift links or springs that connect to the arm to raise and lower the deck? Model Number 42516X92B/skynz71@yahoo.com
完成的
Having the same problem with my cub cadet 1420. Could you possibly find a diagram for it? Thanks
完成的
I have a husqvarna GTH2654 the deck won't raise or lower either.
完成的
I'm having the same issues for a Ferris zero turn 52 in deck
完成的
添加一条评论
The front end of the deck that connects to the rod wont raise on my troy-bilt hydro
这个答案有帮助吗?
得分 0
添加一条评论
Lifting arm will not raise mower deck on XT1 w/ 46” deck?
这个答案有帮助吗?
得分 0
1条评论:
My Deere mower
# Z997R 72" deck will not raise or lower. The height adjustment dial won't turn at all. Also, the switch on the handle that raises and lowers deck isn't working as well. Where do I start troubleshooting these two issues?
完成的
添加一条评论
添加你的答案
tanyafaucett 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 13
总计 7,219
