跳转到主内容
2.3GHz, 2.6GHz, or 2.7GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.7GHz) with 6MB shared L3 cache.
Help Finding Resistor and Capacitor Values on Logic Board
Hi folks!
I have a Mid 2012 MacBook Pro with Retina display (A1398, EMC 2512) that experienced some liquid damage. A small amount of juice got into the MacBook and completely burned out pin 1 on the internal DisplayPort connector, which I identified as the backlight power pin. (The data pins still worked and the computer still booted up fine, but the backlight was completely gone.) I was able to install a new connector but ran into some troubles. This was the first time I'd ever used a rework station, so I accidentally blew off an inductor, a QFN package, and 3 of the smallest capacitors and resistors I have ever seen. I was able to reinstall the QFN and inductor without too much hassle, but the very tiny components were blown to God knows where.
I lost half of these guys. (The ones handing on by a thread were both lost ) At this point I hope to remove all of these tiny components, clean the pads, and use solder paste to put on a fresh set in one go.
Here is the location of the components on the logic board:
(NOTE: multimeter probe for scale)
From right to left, the missing components are labeled as:
R9000
R9001
R9002
C9028
R9003
C9029
My question is as follows:
1) What are these component values?
2) What type of package do these components use?
3) Where's a good place to source parts like this?
Thank you in advance for your help!
Bunker
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
5个答案
已选择的解决方案
First, turn down the air on your hot air station! I have never seen anyone blow off components unless it has been knocked, or being soldered on with leaded solder!
There are too many components to list down the specifications here; just grab a schematic for your board (820-3332) and ctrl+f the component references you listed; this will tell you the values and package size.
You can buy these from mouser, digikey, farnell or anywhere which sells resistors, capacitors, etc. This, or you can order a donor board and swap them across.
这个答案有帮助吗?
得分 3
添加一条评论
Thank you for your help, Reece! I'll go ahead and clean up my question and provide a specific answer to my question below. If you're attempting this repair, I highly recommend reading the board view and schematic yourself (links at bottom of post).
I was able to find both a correct board view and schematic. From that, the component values are:
R9000- 0 Ohms (Just use a jumper)
R9001- 1M Ohms
r9002- 1M Ohms
C9028- 0.1uF
R9003 - 1M Ohms
C9029 - 0.1 uF
All of these components have a package type denoted [0201].
NOTE: Please see the board view and PDF for tolerance, temperature rating, and dielectric composition, ect.
Openboardview(open source board view software): http://openboardview.org
Schematic and board view for 820-3332:http://www.apple-schematic.se/board/820-...
这个答案有帮助吗?
得分 1
添加一条评论
Hi Eugene,
This is C6960, a capacitor. Its value is 1uF. It is not essential to the operation of the machine, but at the same time, there is probably a good reason for it to be there. Here is a portion of the schematic detailing that component (in yellow)
这个答案有帮助吗?
得分 1
1条评论:
Hi Allen,
thank You very very much! That is what I am looking for!
完成的
添加一条评论
Hi
Where did you buy this resistors, mine is R6950 I can’t find anywhere
anyone can help me with this
thanks in advance
这个答案有帮助吗?
得分 0
添加一条评论
Hi folks
I have a similar problem. Yesterday I changed the battery of my Macbook Pro Mid 2012 13” i5 2.5Ghz (no retina). Unfortunately a small part broke off (see appendix). Do you know the name of this part? It is located above the battery connection.
Fortunately I didn't lose this part. Can I check it for function somehow?
Strangely enough, the Macbook runs without problems. So I can't say what the part is for.
I look forward to your help.
Best regards from germany.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
BunkerS 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 30
总计 4,379
