跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
Are iFixit replacment logic brds for iPhone 6 at risk of touch disease
probably a question for the iFixit crew.
I'm about to buy a new logic board for iPhone 6 as mine is suffering badly from touch disease, although I have never had the grey bar.
Just want to know if I buy a replacement logic board for an iphone 6 from iFixit if the touch IC's have been checked/re-soldered and so on.
Or could the same thing happen again.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
Ok, so the board itself isn't at risk of touch disease, apples crappy frames for 6 and 6 plus are the issue. With that being said, iFixit does offer plates, to help keep the chips in place, as well as new soft covers, if you can't get the old one off and on without hassle
That's weird...can't seem to find em...and I asked for those new soft covers specifically!
这个答案有帮助吗?
得分 4
2条评论:
So, it the common currently accepted solution to resolving the touch issue to replace the logic board and then to place a plate on it? I know this is a year-old comment but I am having a hard time finding what the currently accepted solution is that doesn't involve rewetting the solder under the IC.
完成的
@kupajava The current best practice is to remove the Meson IC, place a micro-jumper on the M1 pad and reball Meson. No need for a plate. This is about as permanent a solution as you can get.
完成的
添加一条评论
Theoretically, it could. However, iFixit stuff is great quality. If your motherboard is affected by touch disease, it is backed by their awesome lifetime warranty. I don't know exactly where there sourced, but if I had to guess I'd say they came right from some new iPhones. Utmost quality.
Hope this helps!
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
pep073 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 107
