The canister is empty after I vacuum a room
When I vacuum a whole room the canister is empty. But the floor is somewhat clean
If your Shark Navigator Lift-Away Pro no longer sucks up dirt, dust, and debris, see the Shark Navigator Lift-Away Pro Loss of Suction problem page for possible causes and solutions.
If your Shark Navigator Lift-Away Pro no longer sucks up dirt, dust, and debris using the vacuum’s nozzle, see the Shark Navigator Lift-Away Pro Loss of Nozzle Suction problem page for possible causes and solutions.
这个答案有帮助吗?
过去 24 小时: 4
过去 7 天: 28
过去 30 天: 65
总计 1,829
3条评论
I am having the same issue. Have cleaned the vac from top to bottom twice, removed some clogs (cathair), took the vac apart and changed the filters. One clog was in the handle between the junction of the Suction Release coupler and goes backwards towards the hose connection. I cleaned that out and put it back together. After vacuuming again, the handle was clogged again, The vacuum is picking up, but when done, the canister is empty after vacuuming the room. I'm stumped. Can anyone help?
由 Lee Anne Dunn 完成的
I am having the same exact problem!! My vacuum cleans and picks up the room, but the canister is empty! And the next time I go to use it it is not picking up so good, and so me and my husband take apart the vacuum and unclog the hose! We can not figure out why this keeps happening!!
由 Virginia Bailey 完成的
I'm having this same issue along with it being extra loud!
由 Lynzy Mikkelsen 完成的
