跳转到主内容
iPhone 6s Plus 发布于2015年9月25日,有两个型号A1687、A1634,网络制式有GSM、WCDMA,存储容量有16GB、64GB、128GB可选,机身颜色有银色、金色、深空灰、玫瑰金。维修iPhone 6s Plus和前代产品相似,需要螺丝刀和撬棒等。
Apple Support diagnosed proximity sensor problem
I got an iPhone 6s+ for free from my aunt but the screen simply wouldn't auto adjust brightness. I tried a lot of calibration and "fixes" online and never got it working. I sent it to an Apple Authorized Repair Center but they claimed that my phone has been taken apart and they'll charge me around 400USD for a refurbished phone(I still have a month of warranty left). Now my question is is the sensor tied to the screen assembly? Will I be able to fix it by replacing the screen or is it even easier to fix the sensor. Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Yeah, if that's the issue, it's not a big repair.
Parts
iPhone 6s Plus Front Camera and Sensor Cable
Labor
iPhone 6s Plus 前置摄像头与光度感应器组件更换
Replace a front camera and sensor cable compatible with the iPhone 6s Plus. Includes the front camera, secondary microphone, ambient light and proximity sensors. Part #821-00153-A.图片
产品
$29.99
这个答案有帮助吗?
得分 2
3条评论:
But from the comment I've read under the guide people have brightness based issues after doing the repair(calibration issues I believe)do you have any ideas why or how to fix? Thanks
完成的
The "calibration" is a lot more of an apple scare tactic, than anything else. What do you mean "auto brightness"? Lemme look further into this...
完成的
Yep! Just tested mine! It's totally the front camera flex!
完成的
添加一条评论
最有帮助的答案
Your proximity sensor is bad. If you know little bit about phones. You can change it by yourself. Just buy a new proximity sensor flex and use the right tool to open the device and change it. It should solved the issue.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Stanley Chen 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 308
