跳转到主内容
加入维修社区 - 创建账户
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 128 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
home button not working after battery replacement?
Hey guys i just changed my battery on my iphone 6s and my home button stopped working? i unplugged the ribbon cables everywhere and plugged them back in and nothing my home button still does not work. any ideas ?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 11
1条评论
Meticulous battery replacement on iPhone 6S, careful not to stress any cabling, assembled and then, presto, home button not functioning! Growl..... Undo all connections and re-do and presto, home button still not working. Read all the conversation on this and conclude that there are no gold clips, just fairly clean. Plan to take it into Apple Genius Bar and possibly call the minister. I hesitate to upgrade, because 6S is the last iPhone with audio jack and I won't put wireless earbuds next to my brain. I would appreciate any help on this, if anyone knows what to do. Thanks in advance.
完成的
添加一条评论
7个答案
最有帮助的答案
Hey guys! I have a problem with my iPhone 7. Its battery wa damage during charging. It gives me low battery timing. So, I replaced my battery. After that my iPhone’s home button does not working and show the pop up “ Touch id loads to fail on this iPhone”
What can I do?
Before battery replacement my iPhone wa properly working.
这个答案有帮助吗?
得分 2
3条评论:
Hi all
My phone is i phone 7 , my phone is 1 year and 4 months old so my battery discharge faster, so I order the battery in online and use YouTube to replace by myself. as of my knowledge, I never touch the home button area . but still when I test with new battery, I have the same issue (Unable to active touch ID). I browse lot of website finally I come to know apple software design to lock or deactivate the home button when you open by unauthorized apple store.
完成的
I replaced the battery with a kit. Home button does not work. I broke a ribbon cable going to the screen. My fault. Heck. Suggest check all three cables going to screen.
完成的
I also broke the ribbon cable! I’m sure it is my fault I didn’t follow tutorial so I’m using accessibility button anyway I can replace cable iPhone 6s
完成的
添加一条评论
Yes the flex cable or one of the connectors in that area to the screen is being pinched down to hard by the metal cover above it. Loosen the 4/5 screws depending on your model that covers the cables and you should be fine.
这个答案有帮助吗?
得分 1
添加一条评论
If phone is opened by someone other than apple the home button doesn’t work !
If anyone knows how to reset it please let me know !
Rdsvideo3@yahoo.com
这个答案有帮助吗?
得分 1
添加一条评论
If you dont make a move or doesnt move the home button while installing the battery maybe the problem is you didnt put the lcd well to the housing :)
这个答案有帮助吗?
得分 0
5条评论:
You may not put the ribbon cable well also on the logic board or definitely try hard resseting your phone if it doesnt solve the problem its on the hardware itself maybe you damage something inside.
完成的
the screen is seating perfectly fine ?
完成的
Try removing the screen and put it back again maybe the ribbon cables is not properly intact .I already encounter that on 5/5c/5s and se the only problem is the screen doesnt lie perfectly on the housing itselff if it didnt work try hard resetting the phone .do you unscrew the home button ?Or somethin on the screen ?
完成的
Or someone blocking on the continuity of the home button to the board located at your charging port .Thats why im asking if the phone is not perfectly intact on the housing because sometimes the continuity is break because it didnt have physical contact .its like a sensor that means the phone is being pressed or not
完成的
Just to note make sure battery is unplugged when unplugging or plugging screen cables to logic board.
Also have you tried turning phone off and on?
完成的
添加一条评论
The metal cover above the lcd cable is too tight. Loosen it and then you should be okay.
这个答案有帮助吗?
得分 0
添加一条评论
If you have a screen available, try it out in a new screen. The ribbon that runs from your button to the board is part of the screen (unfortunately). That ribbon being damaged would actually be the cheapest fix, so hopefully that helps. Replacing the button or the board would be expensive.
这个答案有帮助吗?
得分 0
添加一条评论
Hi,
I took my 6S Plus in to a third party repair shop for loud speaker replacement; after repair, my home button started having problems, it was seldom working; i took it back to the shop, they replaced the home button, telling me that I will no longer have touch id; when asked what happened to the home button in the first place, they said it's common that the home button starts having problems. i'm having a lot of trouble accepting this shady information. the button was working perfectly fine; i take it in for repair, unrelated to the home button, and now my home button seldom works. this is an old phone that has been handed down to the kids, so not having touch id is fine, but still, this is some shady info and practice. i have taken my phones in to third party repair shops a few times and they've ALL been bad experiences. I don't know if the Apple store does these kinds of repairs but I will be going straight there next time I need something repaired.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
[deleted] 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 21
过去 30 天: 51
总计 14,311
