跳转到主内容
The Samsung Gear S3 is the third-generation Samsung Gear smartwatch, first released in November of 2016. Features a round OLED display running the Tizen OS. Model number: SM-R770NZSAXAR.
67 个问题 查看全部
The four back screws
i want to open the back of my samsung gear s3 but i do not know if the back screws are tri-point type or tri-wing type? also, i want to know the type and size of the screwdriver that can turn these screws. please help!!!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Hey I will like to know where I can buy four rear screws for my gear s3 classic
完成的
添加一条评论
2个答案
最有帮助的答案
Hi!
The screw type is a tri-point Y0. You can get the screwdriver in the 64 bit driver kit from the ifixit shop.
这个答案有帮助吗?
得分 1
1条评论:
would you happen to know the size of the screws? I stripped one and need a replacement. thanks.
完成的
添加一条评论
i have the samsung gear 3 as well. I tried to remove the 4 screws in the back. 2 came out perfectly and the other 2 are now stripped. Any advise on how to remove the stripped screws?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
rolando de la rosa 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 32
总计 7,733
