it show SOS.can't make a call
how to fix my device problem? i think may be it antenna problem..where the antenna inside curve 8320? thanks..
What happens is there are some very small (a little bigger than a speck of dirt!) resistors on the RF track that have a tendency to come unsoldered and fall off the board. The only place I know that can or will repair it is PDA Repair World. It is not very expensive to have it done, but you will have to call them because I do not see it offered on their site. I have a friend that had the same problem and they repaired it for him.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,291
hadi halim, I can not keep up with the changes in your question. Here you might get the schematics http://www.oldpdf.com/search/Blackberry+... . It would help if you add updates or comments to your question instead of changing your question. Good Luck with your phone.
由 oldturkey03 完成的
