How can I reset my USB ports via Terminal?
So I've made a stupid mistake by messing around with Terminal trying to fix a dodgy USB stick. I entered some commands such as "diskutil eraseDisk HFS+ newdisk disk2" from this website http://hints.macworld.com/article.php?st..., trying a few different options without fully understanding what I was doing. Now anything I plug into either USB 3.0 ports gets the message "The disk you inserted was not readable by this computer". USB drives and hard drives that worked before now no longer work.
I've tried resetting SMC and PRAM to no avail. Would rather not format the whole system as I can't do a more recent backup to HDD beforehand now. But if it comes to it, will this fix the problem?
Can someone tell me what commands to enter into terminal to set these ports back to what they were before I started messing with it?
@jwesterink Does the USB drive show up in Disk Utility?
由 [deleted] 完成的
Try to install clean OS to you computer but before doing so make sure you have created backup of your computer and keep it a safe place. or contact apple support at
(877) 232 0717
由 Amily Grey 完成的
