跳转到主内容
M570 Wireless Trackball Mouse. Released in 2010.
Why can't I connect the mouse to the computer?
The mouse stopped working, and all others are connected without problems with the same receiver, driver and batteries. What happened with the older one? He died for old?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Thank you for your help.
But, The best way to test if the mouse is working properly, is testing another exactly the same as the first, with the same computer, drivers, battery and receiver (of course, using unifying250 for pair them).
The second mouse does't have any problem for connect to the computer. Then, the problem is the mouse only, and I was looking a reset button in the mouse, thinking that the mouse is in an infinite programming cycle, but I didn't find that button.
I don't know what to do with the mouse, it looks new...
完成的
添加一条评论
1个答案
Hi Jesus!
Before proceeding further, I would like to ask if there has been any recent updates with your Operating System, or any new software installed. If there was, you can try performing a System Restore to put it back to a previous date when you can probably remember that your device last worked.
As for devices like mice and other peripherals, wear and tear are very common, thus they usually last at most 2 years (if you're lucky).
Hope this helps.
Cheers,
Ken
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jesus Garibay 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 6
总计 2,865
