跳转到主内容
Released October 24, 2011 / 2.2, 2.4, or 2.5 GHz Quad-core Intel Core i7 Processor
405 个问题 查看全部
Device booting to black screen
I restarted my macbook and just after the apple logo appeared there were some flickering lines on the screen and then just a row of vertical red lines. I turned it off and attempted to reboot it but now all that happens is the optical clicks and the front indicator light comes on. Otherwise it's just a black screen, no boot tone.
I attempted reseating the RAM, both slots, a PRAM, SMC reset, and manually removing the battery. I also booted it with no RAM in it and got the beep tones so I believe my logic board is alive.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Logic board has failed - based on the vertical lines and unable to boot.
Check out the last paragraph of this page: https://www.apple.com/support/macbookpro...
The late 2011 15" have known logic board issues and actually had a recall on them. Might be worth calling apple and seeing if they will replace it still even though they ended the program.
这个答案有帮助吗?
得分 2
2条评论:
It was discovered a tantalum capacitor was degrading that was the root issue. Apple placed it too close to the GPU so it tended to cook a bit. Review this answer: Problem with NVIDIA GeForce GT 330M 256 MB?
完成的
Interesting. Thanks for sharing!
完成的
添加一条评论
添加你的答案
Dirk Gunderson 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 7
过去 30 天: 7
总计 423
