跳转到主内容
型号A1367,闪存容量:8、16、32及64GB
How do I Install New Home Button
No where in the teardowns it shows how to remove the home button, or if it comes off. Is it glued on somehow? I need to replace the front assembly of an iPod Touch 4th generation, and all of the replacement parts I can find do not come with a home button installed. Does anyone know how they are attached, if they are at all?
Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
The iPod touch 4th gen has the digitizer and lcd attached and as such should only be bought as a whole assembly. This assy. comes with the lcd and home button attached. The home buttons are behind a metal flex plate which is plastic welded into place with the ribbon cable and switch behind them. Find a suitable replacement assembly that includes the lcd and home button as a replacement and you will save yourself some grief. ebay has them as well as other iPod parts distributors.
这个答案有帮助吗?
得分 2
添加一条评论
I purchased a new lcd/digitiser but it did not come with a new home button. I've used my old one as there were no problems with it, but no I've replaced the screen it doesn't want to work. The flex hasn't been tampered with at all so should still work. How can I test to find out what the problem is? If I take the metal plate off and look underneath, there is the 'spring' that is associated with the home button. Is there anything I need to make sure that is touching to make sure it is working?
这个答案有帮助吗?
得分 -1
1条评论:
Dan,
In order for someone to help you need to please post this as a new question so everyone sees it.
完成的
添加一条评论
添加你的答案
Josh Forester 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 2,911
