跳转到主内容
Apple的 MacBook Pro 的產品線是專為可望極致效能專業使用者所打造。MacBook Pro 产品线包括了MacBook Pro 13" (一體成型機身款), MacBook Pro 15", MacBook Pro 15"(一體成型機款), MacBook Pro 17" 和 MacBook Pro 17" (一體成型機款)。
20001 个问题 查看全部
What is the best way to prevent keyboard marks?
If you're not careful, over time keyboard rub marks (particularly on the center row) can render a display almost unusable. This issue was particularly pronounced for me when I carry my MacBook Pro around with me in a backpack with lots of equipment.
I've used a piece of paper in between the keyboard and screen, and that gets the job done but isn't terribly elegant. What works best for you?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 11
1条评论
https://www.youtube.com/watch?v=8pj9SCgT... this has removed the marks from my laptop screen.
完成的
添加一条评论
13个答案
已选择的解决方案
Well on my white MacBook, I've been using the thin sheet of perforated material that the laptop shipped with.
If that doesn't work out for you, I would try one of the many third part alternatives such as
http://www.radtech.us/Products/NotebookS...
Hope that helps
这个答案有帮助吗?
得分 7
添加一条评论
Another possibility; look for an optical cleaning cloth (often found at opticians or camera shops) of the necessary size (or trim accordingly). Use this between the keyboard and screen (nice and thin) and doubles as ...a cleaning cloth. Much cheaper than some of the commercial options.
I use a fine piece of leather, which also can be used as a mouse pad on rough/reflective surfaces.
这个答案有帮助吗?
得分 5
添加一条评论
Get a screen protector from OWC. Been using them for years and they work flawlessly.
http://eshop.macsales.com/item/Other%20W...
这个答案有帮助吗?
得分 2
1条评论:
Do you think they're better than the Radtech screen protectors? I like those because I can use them as a screen cleaning cloth, too.
完成的
添加一条评论
I have used for years a Kensington Micro fiber cloth - It looks like gray suede, exactly the right size to protect the entire screen... I carry my 15 everywhere and haven't treated it particularly gently, I don't think. The screen looks brand new.
这个答案有帮助吗?
得分 2
添加一条评论
It seems mine collects a lot of dust so I keep a microfiber cloth (think Billy Mays) over the keyboard and when I'm ready to use the Mac I dust everything off and as a bonus, if I wet it a tiny bit I can even clean of my grubby fingerprints. This is also the least expansive of the tips
这个答案有帮助吗?
得分 1
添加一条评论
Check if the little plastic pads on each top side of the screen are still here and not cut. They serve to keep a small distance when the screen is closed. You can increase distance with added thick adhesive tape.You can try to add two thin little pads on bottom of screen too. Check for the needed thickness with the screen closed to keep the hook grabbed on bottom part.
Eventually try to adjust the hinge height to increase distance to keyboard.
And never put big objects on screen size when you carry the Mac in backpack or use a sheet of hard material (metal, epoxy,..) as separator to avoid any pressure on the top cover.
这个答案有帮助吗?
得分 1
添加一条评论
I have used the ShaggyMax protector on every laptop in the last 9 years. No marks / great resell value!
http://www.shaggymax.com/laptop-screen-p...
这个答案有帮助吗?
得分 1
添加一条评论
I just found out today, after replacing my screen, that the marks are caused by the oil and acids from your fingers, and not by the pressure from the keys. The marks are damage to the anti-glare coating, and, as such, are not actual stains that you can clean off without removing the coating altogether, which is an option. SO, you need to clean your hands and keyboard regularly with isopropyl alcohol. There’s kind of a funky solution, if your screen is really bad and you’re feeling adventurous. You can remove the coating altogether with a soft cloth, Listerine, and some time. Sounds ridiculous, but I’ve done it myself. Then, if you can’t stand the glare, you can apply a third party screen protector like the ones you put on your phone.
这个答案有帮助吗?
得分 1
添加一条评论
I like Mareware http://www.marware.com/products/MacBook_... it includes a two-in-one microfiber keyboard cover & cleaning cloth. a Soft PVC leather hand rest, (provides protection to the top case sides that scratch/discolor), and a clear film track pad cover.
There's also a Silicone version of the hand rest and track pad protectioni, with cleaning cloth for keyboard and screen.
N.
这个答案有帮助吗?
得分 0
添加一条评论
Clean your hands before you use the keyboard. Sure it can be a bit of a pain, but it will keep your keyboard clean. To make this a bit easier you keep a can of hand sanitizer next to your computer on your desk.
这个答案有帮助吗?
得分 0
添加一条评论
Any sort of skin/keyboard cover which cover's should work, but i'd advise a screen protector as well, as the keyboard cover itself could leave a mark
这个答案有帮助吗?
得分 0
添加一条评论
I never close the lid.
这个答案有帮助吗?
得分 0
添加一条评论
Please check the following video worth watching showing how to take care of your Mac book Pro and also keeping it dust free.
http://tinyurl.com/mekv7vv
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kyle Wiens 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 23
过去 30 天: 139
总计 101,135
