跳转到主内容
2014年9月19日发布的iphone 6 Plus有着比iphone 6大的5.5英寸屏幕。
1525 个问题 查看全部
Touch issues even after screen has been replaced
Bought a 6 plus that had vertical lines down middle of the screen and did not respond to touch. No screen flickering or line at the top so thought that it might need a screen replacement. Replaced screen, vertical lines are gone but the touch issue is still there. Not responding on any part of the screen.
Am I looking at touch disease or does anyone have any other ideas?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Check the touch screen connector on the logic board. It's the wide horizontal one below the rear camera on the logic board.
Could be dirty, physically damaged or worn out.
Also check for signs of liquid damage. The are various LCI (Liquid damage indicator) stickers placed on the logic board.
One at top of board another behind screen assembly back metal plate.
They are initially coloured white to mean it has not been in contact with liquid / moisture.
Once it's red it means it has been in contact with moisture.
Can still be touch ic disease as they can be shown even without grey horizontal bar at top of screen.
You can sometimes get the grey bar to appear by slightly flexing the metal iPhone frame. Only do it slightly / a bit for testing (don't force it tho)
这个答案有帮助吗?
得分 2
1条评论:
Hey,
Thanks for your reply. It's a bit of mystery at the moment. There is no sign of any water damage on any of the indicators. I used a camera to zoom up real close to the connectors and there doesn't seem to be any sign of any damage. I'm going to take it to a shop that I use for stuff that is above my pay grade tomorrow and will respond with the results.
完成的
添加一条评论
cured my 6 plus touch issues by removing the logic board, peeling the sticker back from the touch IC chips, folding clean white piece of paper to four layers thick and trimming it to fit under the sticker, put it back together and it's fine. The contact point under the IC chip must have a crack and the paper is putting just enough pressure on the chip to maintain the connection. I don't have the tools (yet) to refloat/resolder the chips.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Mary Ellen 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 187
