跳转到主内容
iPhone 6s Plus 发布于2015年9月25日,有两个型号A1687、A1634,网络制式有GSM、WCDMA,存储容量有16GB、64GB、128GB可选,机身颜色有银色、金色、深空灰、玫瑰金。维修iPhone 6s Plus和前代产品相似,需要螺丝刀和撬棒等。
1041 个问题 查看全部
iPhone 6s Plus Dead while charging and the voltage not stable
My friend just bring me his iPhone 6s Plus and it completely dead and I check the charging port ok and lcd is good and try power it with another full charge battery nothing happen. So I try to check short with multimeter I can see a very little short and when I connect USB cable to the charging port and measure the voltage in battery connectors it 4.5 and drop to 0.25 to 1.25 then 4.5 then 2.5 not stable can any one help me where should I start
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Ask him if anything happened to the phone before it happened. Or did it suddenly happen for no apparent reason?
完成的
charging Dead iphone 99% solved for change ic .........
http://forum.gsmhosting.com/vbb/attachme...
完成的
添加一条评论
1个答案
已选择的解决方案
It's the tristar. Gonna go ahead and guess it's from over use with an aftermarket charger cord, which the person blew the first battery, and then left it on the charger to continually use it, and the tristar has now failed. If you have experience with microsoldering, then this is a good answer, if not send it to a board repair shop. Many of them have a mail in service
这个答案有帮助吗?
得分 5
3条评论:
According to you he used the iPhone 6s Plus with a power bank case it charge his phone always. That could coz the problem-- one more thing i do micro soldering but I want to know is the iPhone 6s and 6s plus Tristar same
完成的
@refectio is the tristar on 6S replaced by Tigris? If so is it compatible with 6S+?
完成的
The iPhone 6S/6S+ uses the 1610A3 version of Tristar.
完成的
添加一条评论
添加你的答案
Sami Islam 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 1,199
