跳转到主内容
The C720 is a low cost Acer ChromeOS based Chromebook. Released 2014 successor to the C710.
26 个问题 查看全部
Why won't my battery recharge?
My charger stopped recharging my acer c720 laptop. I got a replacement power cord but it won't charge. If I unplug it the system goes blank. As long as it is plugged in, the computer it works. I can't get into the back of it to see the internal battery. There was a puff of smoke from the back and that was it.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Acer C720 Motherboard Replacement
You can basically follow that guide on how to open it, once in your on your own.
https://www.amazon.com/Acer-Chromebook-B...
There is the new part. The smoke isn't a good thing. It could mean that somthing fried. If the new battery doesnt work, return it and get a new chromebook as your chromebook is toast.
这个答案有帮助吗?
得分 1
1条评论:
If you wanted to help this person, you'd try to locate what part burned out, test the motherboard to see if it's intact, see if another battery would work. Check to see if the battery poles were matched up correctly, or not--just that could fry a notebook.
完成的
添加一条评论
添加你的答案
Carmen Leach 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 12
总计 402
