跳转到主内容
Valve Steam Controller, released November 10th 2015. Model 1001.
21 个问题 查看全部
One of my triggers works ok but got squishy
My steam controller left trigger works when you pull it but doesn't have that 2 stage feel to it. It's as though the piece stopping the trigger just before the 2nd stage is gone and it just squishes into the button. I like the controller and I want to fix it instead of buying a new one. Is there some kind of trigger replacement possible?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
you would be looking at a full logic board replacement. The haptic sensation from the second-stage push-down on the trigger occurs when the trigger assembly places pressure (from your finger) on an embedded metal tensile pad which will click when enough force is applied to it. There's no feasible way of removing and replacing the sensor as it's metal appendages are folded into the PCB board.
Your best bet would be to leave the warranty stickers (covering the three internal PCB screws) in tact and contacting steam customer service, otherwise you're probably looking at a new piece of hardware.
rip.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Mark Wright 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 189
